New Build Thread?
Old 12-03-2011 | 10:56 AM
80ZJoe's Avatar
July 2010 ROTM
Some nice progress goin on here, i redid my inner fenders and rad support up real nice and the bodyshop got over spray all over them m
  #152
Old 12-03-2011 | 12:26 PM
rydeer's Avatar
Thanks Joe! I don't plan to send it out assembled and I want the inner fenders body color.
77Nomad I was out sanding this am feeling sorry for mayself as I was sanding the plastic parts. Then I thought of you sanding rubber, That must be way worse. I also knew I'd be painting again so I fired up the heater to 65.Very tolerable...
  #153
Old 12-03-2011 | 12:29 PM
rydeer's Avatar
So I went out early and sanded and cleaned so I could spray more primer.
Hard to see with the fog in the air!!LOL
Attached Thumbnails New Build Thread?-001.jpg   New Build Thread?-002.jpg   New Build Thread?-003.jpg
  #154
Old 12-03-2011 | 12:51 PM
My rubber nose is sitting up on a shelf. I haven't touched it. I scuffed it for the repaint yrs ago and that all has to come off. I am saving that until the end. Its gonna suck. I was out last night filling all the spot welds on the firewall. I also removed the tab that goes behind the master cylinder. The one that holds the wires. I had to fill the crater I made when I ground it out. Then made a better template for the panel to smooth it out.
  #155
Old 12-03-2011 | 01:07 PM
rydeer's Avatar
So I let the fog clear a little. The one in the shop,the one in my head has been unchanged for years!!!
Took some new pics. The fender that I welded together looks great. The other one(the one I chemically stripped) looks like someone beat the top with a ball peen.
  #156
Old 12-03-2011 | 01:11 PM
iLL95's Avatar
I Like to Party
Super Member
Was it because of how you stripped it (You mentioned "beat the top") So is it damaged?
  #157
Old 12-03-2011 | 01:13 PM
rydeer's Avatar
some kinda prob on the page ,try again
Attached Thumbnails New Build Thread?-008.jpg   New Build Thread?-009.jpg   New Build Thread?-010.jpg   New Build Thread?-012.jpg   New Build Thread?-013.jpg
  #158
Old 12-03-2011 | 01:14 PM
rydeer's Avatar
I didn't beat it. The chemical removed prior bondo and I now see it.
  #159
Old 12-03-2011 | 01:17 PM
rydeer's Avatar
I'll be filling and block sanding.. The wheelwells and the rad support are prob done until paint. The other parts will need body work first and another prime!
  #160
Old 12-03-2011 | 10:13 PM
Well now I'm starting to get behind.
Quick Reply: New Build Thread?
