New Build Thread?
#91
OK so I started on the cowl area. Can someone with a non ac car tell me what goes in the cowl area on the Pass side. I've removed the flap that was there and a semi block off plate thingy. I plan to use nothing. I can't figure where the water that drains in should come out? This cowl area conects inside the lower fenders ande must go in side. I see a flap on the pass side but not the drivers.
On the cowl top (Nomad did you do this?) I'm not going to use seam sealer. I'll just bondo it. I want to flatten this area out better than the factory did.
I've sanded and primed it so far. Tomorrow is another day.
#92
Rant over. I think I'm ready now.
#93
I laid into the cowl with 80g. Then just primed. I'm not trying to add weight. As for the drain its on the bottom where you asked some time ago. I think its near the fender bolt hole but I would have to look to be sure.
#94
Snow is melting!!!Yay!
I'll just drill some holes on both sides.
The pics don't show very well. There were lots of wrinkles and spot welds that I've smoothed out. I have a final coat of bondo on and I'll sand and glaze it later. I have the w. wiper assy off, I'm not sure if I can powder these.Any body taken the bushing apart on one of these? Is there any rubber stuff inside? I have them all blasted and ready to go!
#95
I wouldn't powder coat the wiper assembly. Besides the motor, there's bushings, etc. that wont do well at 260 degree temps used in powder coating. Just shoot them with paint.
#99
Don't use that powder coater then. The powder will not be cured. It needs 20 mins at 400. Clears use 375 to help keep from yellowing. I buy from several supliers and they are all the same! The 20 mins start when the part is at 400. not the oven.
