My 1970 Camaro w/ 572 Build
Old Dec 6, 2015 | 01:45 PM
  #541
clacia's Avatar
Would not even hear it running once the 572 is idling pissed off
Old Dec 7, 2015 | 12:11 AM
  #542
Sudstoy's Avatar
Yes clacia, I am thinking about Easy-EFI 2.0. If I do pull the trigger on it I will get the kit with the inline pump and self learn function. I spoke to FAST about this and the kit can handle up to 1200hp. If and when I go to a supercharger i only would need to change out the ECU/ECM whatever its called and a couple small sensors.
The Saudi's had a cartel meeting on Friday though and didn't set a limit for oil production and stocks took a beating. My world gets more uncertain every day and I'm pretty sure that I'm not gonna drop the money on the car until oil prices stabilize.
Old Dec 7, 2015 | 01:34 PM
  #543
clacia's Avatar
I know how you feel. My salary also depends directly on oil companies. And I feel the same when I spend money like stupid on the car!!! And now that my wife is pregnant again, I am feeling it more.
But I cant stop now. There is no point of return and I have to finish this project. The money "invested" in the Camaro will go down the drain if I stop. Now close to 35K spent and still a long way to go !!
Old Dec 8, 2015 | 06:10 AM
  #544
Sudstoy's Avatar
You know as well as I do that the 35k is just a drop in the bucket from what the final amount will be. I am just taking some time away from mine for now, i will see how i feel about spending the money in the new year. I can easily afford it but every day that I am at work reminds me that I want to retire early to be able to enjoy the toys that I do have and in order to do that careful planning has to be done.
Old Dec 8, 2015 | 09:17 AM
  #545
woh just looked and price of crude oil is crazy low,,, maybe a side job working on camaro's?
Old Dec 8, 2015 | 11:48 PM
  #546
Sudstoy's Avatar
Haha I actually did that my last time home from work, i went and got a 78 trans am running at my buddies shop, it took me all of 10 minutes to realize that I don't like working on other peoples cars.
As for the price of oil, the company I work for has laid off 1700 people out of 4500, and we have taken an 11% roll back in wages. Its a scary time.
Old Dec 9, 2015 | 02:17 PM
  #547
clacia's Avatar
That is very sad.... Hope things get better.
May I ask you please to take a picture of your bulk head / firewall where you had to make the mod for the distributor cap to fit?
Thank you.
Old Dec 10, 2015 | 12:23 AM
  #548
Sudstoy's Avatar
I will try to remember to take a photo of the clearances next time I am out there, currently I am 12 time zones from home working. I did not have to make any modifications for the distributor to fit.
Old Dec 10, 2015 | 02:05 PM
  #549
clacia's Avatar
I thought once you told me that you had to hammer a bit the fire wall to accommodate the distributor cap. Maybe I am wrong.
Yes please if you remember a picture will be appreciated.
The fuel pressure should be around 7psi to the carb. And I noticed as well that you have 750 cfm carb? The 572 I am going for has 1050 dominator.
Quite a difference. Maybe you should try and swap to a larger carb?
Not so long ago you said that the engine was running perfect. Maybe you have some residue in the tank which is restricting fuel?
Just trying to help.
meanstrk
Apr 26, 2015 08:47 PM
mattzoom
Aug 29, 2009 05:11 PM
70camaro
Aug 11, 2007 10:58 AM
Speedy LT1
Jun 27, 2006 02:13 PM
