Central Oregon 78
#113
Adjusted valves, got timing set, drove up and down road 2 miles bring RPM up to 2500 and then letting off and slowing on compression. Changed oil, every thing looks and sound good. The one little tic that I hear, has something to do with the power steering pump ( push on pump and sound starts to go away).
#114
Should be close enough. Just don't go any less with the new style lifters that have the wire clips. The snap ring retainer lifters were/are much better, and can be run looser without flying apart.
#115
#116
Found the "tic". Of all things it was the front header bolt that holds part of the PS bracket. When I retightened the header bolts I tightened the outer nut (its a double nut, one on each side of the bracket), took bracket off, tightened inner nut, reinstalled bracket, no more "tic".
#117
#119
Got the car street legal, so I've been trying to get some miles on it. Got a total of 40 on it so far and its running great. Looking forward to getting a couple hundred on it so I can start pushing its limits some.
#120
Wont hurt to push it a little even during break in Bill. I have always run mine out a bit and given them a variety of driving during break in. Bet it's fun to have a nice gear ratio, and a new tight engine now! More smiles per mile!
