Central Oregon 78
Old Mar 2, 2014 | 03:27 PM
  #111
Sounds great Bill. Yeah, I could hear a loose lifter also in the video. Are you setting them a full turn after zero lash?
Old Mar 2, 2014 | 06:43 PM
  #112
Shalamara's Avatar
March 2013 ROTM
If I remember right we only went 3/4 turn.
Old Mar 3, 2014 | 07:02 PM
  #113
Shalamara's Avatar
March 2013 ROTM
Adjusted valves, got timing set, drove up and down road 2 miles bring RPM up to 2500 and then letting off and slowing on compression. Changed oil, every thing looks and sound good. The one little tic that I hear, has something to do with the power steering pump ( push on pump and sound starts to go away).
Old Mar 4, 2014 | 10:06 AM
  #114
Should be close enough. Just don't go any less with the new style lifters that have the wire clips. The snap ring retainer lifters were/are much better, and can be run looser without flying apart.
Old Mar 4, 2014 | 10:07 AM
  #115
Are the mounting points all snug, or something internal loose in the pump?
Old Mar 4, 2014 | 04:11 PM
  #116
Shalamara's Avatar
March 2013 ROTM
Found the "tic". Of all things it was the front header bolt that holds part of the PS bracket. When I retightened the header bolts I tightened the outer nut (its a double nut, one on each side of the bracket), took bracket off, tightened inner nut, reinstalled bracket, no more "tic".
Old Mar 5, 2014 | 10:02 AM
  #117
That's pretty good for as far as you had the car torn down! I usually find a few little things that either work loose, or I missed getting fully tight. I always go back over the header bolts 3-4 times before they finally stay tight!
Old Mar 5, 2014 | 04:24 PM
  #118
Yes header bolts are a pain. I go over mine when ever the hood is open.
Old Mar 14, 2014 | 03:27 PM
  #119
Shalamara's Avatar
March 2013 ROTM
Got the car street legal, so I've been trying to get some miles on it. Got a total of 40 on it so far and its running great. Looking forward to getting a couple hundred on it so I can start pushing its limits some.
Old Mar 14, 2014 | 07:15 PM
  #120
Wont hurt to push it a little even during break in Bill. I have always run mine out a bit and given them a variety of driving during break in. Bet it's fun to have a nice gear ratio, and a new tight engine now! More smiles per mile!
