79 Camaro Project
Old Jul 24, 2012 | 03:32 AM
  #791
I had to drill mine. I f'ed one of the doors up in this area and will need a bit of hammer and dolly to bring it back. Thread lightly here. The metal is thin but the screws are rock hard, It took several bits to get mine out.
Old Jul 24, 2012 | 06:55 AM
  #792
ATM's Avatar
ATM
I used to have an impact screwdriver you hit with a hammer that would be perfect.
Old Jul 24, 2012 | 07:24 AM
  #793
I use a screwdriver, one that can take a hammering, and whack it on the end with a hammer while trying to turn the screw. Works pretty darn well as an impact.
I do have a hammer impact screwdriver, but snapped most of the decent sized bits. They don't seem to make bits as well as they make an actual screwdriver.
Old Jul 24, 2012 | 10:46 AM
  #794
I use an impact screwdriver also, but heat and penetrant will help it work better. I try to reapply the heat and penetrant a few times before using the impact. Might give it a better chance to work.
Old Jul 24, 2012 | 11:33 AM
  #795
Beware though, painted surfaces don't like getting heated up, even from the back side!
Old Jul 24, 2012 | 11:37 AM
  #796
Don't use a torch!!!! I use a soldering iron by putting the tip directly on the screw or bolt head. Works great!
Old Jul 24, 2012 | 04:38 PM
  #797
ATM's Avatar
ATM
By torch I mean a plumbing torch, not for long either. I have some common sense. lol. The soldering iron... that little bit of heat seems like it would just disperse faster than it could be of any significance in a screw that is screwed into a latch into a door that is all metal. Worth a shot I suppose. I'm just going to keep on with the PB blaster for a couple more days.
I never used the impact screwdriver when I worked for NCR, I always wondered about it breaking. I don't like beating on things that are tempered and could shatter (like the tip of the screwdriver). I already popped one eye, and I don't want to have that happen again. If I can't get it out, no big deal, I'll leave it in there and just remove all of the linkages and stuff.
I may be working out a trade for some parts for a pair of power door locks and windows here too, so somewhat perfect timing on that note.
Old Jul 25, 2012 | 08:58 AM
  #798
You haven't seen my soldering iron! It's got a tip that weighs a little over 1 lb. alone. An old one from WWII era that I inherited from my father. It can actually lay down lead on body sheetmetal.
I have used my Weller gun for smaller jobs where I needed more precise heat, as it heats up faster than the old iron does.
Old Jul 26, 2012 | 01:21 AM
  #799
Umm Val. Thats called a welder. LOL
Old Jul 26, 2012 | 09:09 AM
  #800
That iron is so old it's still got a old cloth covered cord on it!
