79 Camaro Project
Old 04-24-2011, 11:04 AM
ATM's Avatar
ATM
ATM is offline
That makes me like it even more then.
  #432
Old 04-24-2011, 04:42 PM
The ps is V belt. Look close. Its ribbed on the outside. I've seen that pic before. He says it has a whine like a blower.
  #433
Old 04-24-2011, 04:46 PM
ATM's Avatar
ATM
ATM is offline
It is swanny454's car. I really like it.
I spent some time trying to clean up my pullies today, the are going to need some elbow grease put into them. Probably just shelf them for a bit until I can learn to polish.
  #434
Old 04-24-2011, 06:24 PM
I wonder where a guy gets those cog pulleys to make that setup?
  #435
Old 04-24-2011, 08:42 PM
ATM's Avatar
ATM
ATM is offline
From this guy.
abad71camaro | eBay
I think I may end up spending alot of money here.
  #436
Old 04-24-2011, 09:42 PM
I can see how I could spend a bunch with him too! I better stop looking before I get crazy ideas!
  #437
Old 04-24-2011, 09:48 PM
You want me to give those pulleys the treatment? I would do it for trade. Not sure what you have I need though.
The cogs are slick huh Val? NO belt slipage.
  #438
Old 04-25-2011, 05:11 AM
ATM's Avatar
ATM
ATM is offline
Actually, if the pulleys were to get the treatment, I want to learn how to do it. Even if it does make my fingers bleed. I was thinking about seeing if I can get some mini buffing wheels and stuff for my die grinder.
  #439
Old 04-25-2011, 09:04 AM
Yeah, I love 'em! Wish I had room for them on my Austin, because that's where I'd really like to use a set! But no room, and they say it's for long water pumps too. So either way I'm screwed.
  #440
Old 04-25-2011, 11:52 AM
I can guarantee bleeding fingers. For sure I took my thumb knuckle down to the bone on a new 36g belt once. The bad side is there is nothing to sew up so they just stop the bleeding and send you home with a bandage. We call them belt burns and I have a lot. Thats how you learn, lol.
As far as doing it at home. Try this. DA the pulleys with 320g then 600g. Your FIL can help you spot the grit left from the 320 if you aren't sure. Then at lowes they have buffing wheels just like the ones we use just 6" diameter. They'll fit on a bench grinder. They have the right compound too. Brown for getting the grit off, white for the dull finish left by the brown. I would rip the guards off the bench grinder too. This will make it easier. Pulleys are the perfect size for this.
I haven't shown you guys me new air cleaner I don't think. It is spun aluminum and I polished it up so I could shave with it.
Quick Reply: 79 Camaro Project
