79 Camaro Project
Old 10-08-2009 | 11:27 AM
5861979z28's Avatar
sounds good keep us postied
  #22
Old 10-18-2009 | 11:27 PM
ATM's Avatar
ATM
Been busy getting ready for winter. Finished painting the house today, closed the pool yesterday and cleaned up 13 bags of leaves and plants that I had to cut down. Oh, and I cleaned my garage. Now I am ready, and I got some good news, maybe I will be able to borrow a rotisserie! That will be a Godsend.
  #23
Old 10-19-2009 | 08:41 PM
Man! A rotisserie would definitely be cool! So nice to work on various parts of the body without being a contortionist!
  #24
Old 10-19-2009 | 08:45 PM
ATM's Avatar
ATM
If I get a rotisserie, do I need to drain all of the brake fluid and remove the rear end?
  #25
Old 10-22-2009 | 07:20 PM
ATM's Avatar
ATM
Will the seats out of a 74 camaro bolt right into a 79?
  #26
Old 10-22-2009 | 07:24 PM
Unless you want to just turn it over and mop upo the oil spill!
  #27
Yes they will!
  #28
Old 10-22-2009 | 07:40 PM
Good lesson in gravity right there!
Some things that are filled while upright have a tendency to leak out when turned upside-down.
A good test would be with a bucket of water over your head.
  #29
Old 10-22-2009 | 08:59 PM
ATM's Avatar
ATM
Actually I was hoping that the rubber seal on the batter fluid tank would keep it in. Probably high hopes. And if I am not mistaken, the rear end is vented, or is it not? If I turn the car upside down the fluid will leak out of it? If I do end up getting the rotisserie I will probably drop the rear end anyways just so I can work on the underside a bit easier, plus I want a reason to find a posi someplace. Missed one today, 12 bolt 4.10 for $200.
  #30
Old 10-22-2009 | 10:42 PM
Ouch!!!!!! That miss hurt! Around here a good 12 bolt with 4:10's will go a grand!
