1978 Camaro Project.
The blue stuff is the prep material you lay down before flooring your house. I'm using it in place of sound dampening material. I've placed it where i removed previous sound dampening material and i've placed it over places i thought "sharp" and might rub raw whatever was placed over it.
Some of that stuff is good for use in basements. I am thinking it would be fine. Definitely something to look into.
If it's the stuff for hardwood floors it should be fine, but don't use the stuff made for carpet pad. That stuff will hold water like crazy.
Also, just as a precaution i left the blue backing on there, which is plastic. If you remove it it's an adhesive backing, but i left it, thus allowing for more water resistance.
Lift straight up on the backs. They have a set of clips that you basically just drop them down onto. On the buckets you push back and then pull up IIRC.
Thanks. And what kyphur said about removing the seats is correct. However, i'd be careful if i were you. Mine were stuck in their really bad, so i did something that now, looking back, was rather stupid. I squatted down, grabbed the seat and lifted. It took a lot of force but the seat finally released... That's when my head made contact with the roof of the car and i received a concussion. Lol, no joke.
#20
Thanks for the info guys!
