1978 Camaro Project.
Old May 5, 2010 | 11:58 AM
kyphur's Avatar
Originally Posted by Bing
The blue stuff is the prep material you lay down before flooring your house. I'm using it in place of sound dampening material. I've placed it where i removed previous sound dampening material and i've placed it over places i thought "sharp" and might rub raw whatever was placed over it.
The only thing I would worry about that is its water retention. If it gets wet how well does it do drying out? You don't want something that will hold water and expedite the rust process.
Old May 5, 2010 | 12:00 PM
ATM's Avatar
ATM
Some of that stuff is good for use in basements. I am thinking it would be fine. Definitely something to look into.
Old May 5, 2010 | 02:29 PM
If it's the stuff for hardwood floors it should be fine, but don't use the stuff made for carpet pad. That stuff will hold water like crazy.
Old May 5, 2010 | 06:55 PM
Bing's Avatar
ATM is correct, they use this in basements, so it's quite good. I had the same concern you had and went ahead and "spilled" some on a sheet and it worked fine. It did absorb some water, but not much.
Also, just as a precaution i left the blue backing on there, which is plastic. If you remove it it's an adhesive backing, but i left it, thus allowing for more water resistance.
Old Jul 29, 2010 | 11:01 AM
Bing's Avatar
so i'm putting the camaro back together right now and i've hit a wall... i've forgotten which wires go to the instrument panel... any help? it's a 79 style panel.
Old Jul 29, 2010 | 02:41 PM
80ZJoe's Avatar
July 2010 ROTM
Old Aug 19, 2010 | 02:50 PM
Tom77camaro's Avatar
Looks great! I am redoing my 77 camaro. How do you remove rear seats?
Old Aug 19, 2010 | 02:54 PM
kyphur's Avatar
Lift straight up on the backs. They have a set of clips that you basically just drop them down onto. On the buckets you push back and then pull up IIRC.
Old Aug 20, 2010 | 08:49 AM
Bing's Avatar
Thanks. And what kyphur said about removing the seats is correct. However, i'd be careful if i were you. Mine were stuck in their really bad, so i did something that now, looking back, was rather stupid. I squatted down, grabbed the seat and lifted. It took a lot of force but the seat finally released... That's when my head made contact with the roof of the car and i received a concussion. Lol, no joke.
Old Aug 20, 2010 | 03:56 PM
  #20
Thanks for the info guys!
scotty1736
May 24, 2013 04:31 PM
wheelergoley
Jun 15, 2010 02:00 PM
daleas88
Aug 19, 2009 10:03 PM
chevyfreak78
Sep 23, 2008 06:30 PM
