1978 project
Old Jun 14, 2010 | 02:32 PM
wheelergoley's Avatar
Default 1978 project
Ok guys. This is my first chevy build. Born a Mustang kid. But when I seen this camaro posted on craigslist and went and looked at it 1,000$ was just to under priced so i figured why not try something diffrent. So I bought it.
Ok now for the good. The body and interior is all original.
Now for the bad. I tood the 4 speed manual out of it and put a TH400 in its place. It is bolted to the back of a 350 (stock other then boarded 30 over). But now i am having transmission crossmember problems. The spot on the TH400 for the mount to bolt to is about 7 inches behind were I need it to be. How can I fix this problem.
Old Jun 14, 2010 | 02:37 PM
Get a 400 crossmember. I belive that the 400 is the only oddball. What kind of tranny did you pull? And welcome.
Old Jun 14, 2010 | 05:35 PM
The problem is not the cross member the crossmember fits the tranny perfect. The problem I am having is the simple fact that there is only one set of crossmember mounting holes in my frame rails. I need another set about 7 inches toward the back to mount the crossmember on. All I know as far as information on the tranny that was pulled is that it was a 4 speed manual and not worth .02.
Old Jun 15, 2010 | 01:49 PM
Drill new holes.
Old Jun 15, 2010 | 02:00 PM
80ZJoe's Avatar
July 2010 ROTM
Hey, welcome to the forum.
I hope you have a propper drive shaft with that th400 cause a stock one won't fit (to long). The 4 speed manual trannies are awsome, i would have left it in if it was in working order, you should check it out see what it is, maybe it's a muncie?
good luck
joe
rubberduck
Jul 31, 2011 08:25 PM
Bing
Aug 20, 2010 03:56 PM
chevyfreak78
Sep 23, 2008 06:30 PM
350z28
Jun 17, 2007 04:22 PM
