1970 camaro swap 350 to 454 help ?
Old 02-05-2012, 08:08 AM
Originally Posted by 77nomad
What all do you get for 150-200 Vall? I swear I found the best deal but I'm gonna kick myself if yours is that much better. I spent I think 115 for the Z-Bar alone.
Ok I over priced my memory. Here is the kit for 215. 1970-1971 Camaro 4 Speed Standard Shift Clutch Brake Pedals & Linkage SS RS Z28 | eBay
Z bar, pedal assembly, rods, throwout arm, etc. They have rows of 2nd gen Camaros and Birds in their yard.
  #22
Old 02-05-2012, 09:53 AM
bad436z28's Avatar
val does that place ship parts at all,wish we had a place like that around here.i would be there everyday and not have a dollar to my name.LOL
  #23
Old 02-05-2012, 02:55 PM
All American does sell all over the USA. Not sure how their shipping rates are, or how phone sales prices match with walk in sales.
Might call them and ask:
Classic Auto ( Automotive ) Parts, Car Wrecking: Chevrolet, Pontiac, Buick, More
  #24
Old 02-06-2012, 11:37 AM
prsjuan's Avatar
another problem got a zoom clutch that is 12" diameter , will it fit the 4 speed borg t10 werner trans, i know i got to change the flywheel to a manual flywheel anyway but my is 14" does the new flywheel need to be 12" too, or is there a ratio from clutch to flywheel. when changing from automatic to manual ?
  #25
Old 02-06-2012, 03:05 PM
ZL1CAMARO's Avatar
Thumbs up
Hey prs Juan, not trying to be smart@$$ ... If you had an automatic there was a torque converter on the 'FLEXPLATE'. For if you have a 'FLYWHEEL' it WAS or IS manual ready. Secondly, you really should balance your flywheel to your rotating assembley in the engine with the crank, rods, pistons, etc. And lastly if your flywheel is used it must be resurfaced for use with a new clutch system for best results. Good luck. I'll try to find out more for you at a later juncture. Also, the bellhousng that mates the trans to the engine would be a determining factor.
  #26
Old 02-06-2012, 05:05 PM
Chevy smallblocks are internally balanced (except the 400) and they are done without a flywheel in place, so no reason to balance a flywheel to the engine unless you've got a need to start winding 7000 rpm or more.
  #27
Old 02-06-2012, 05:11 PM
That depends on which clutch you have and which T10 you have. Both need to either be fine spline, or coare spline. They make the T10 either way, and they make the 12" Zoom either way. Is your T10 a 10 spline, and is the clutch a 10 spline? Or are they fine 26 spline?
  #28
Old 02-06-2012, 06:11 PM
bad436z28's Avatar
just curious doesnt the 4 speed also require the 32 spline 400 turbo drive shaft yoke or can you use the 350 one as imputing 4 speed in mine also.
PurpleClutch
70-81 V8 Tech
01-29-2010 06:40 PM
mattzoom
08-29-2009 05:11 PM
1badhonda1
06-17-2009 09:36 AM
70camaro
08-11-2007 10:58 AM
Quick Reply: 1970 camaro swap 350 to 454 help ?
