1970 camaro swap 350 to 454 help ?
Old Feb 1, 2012 | 12:35 PM
prsjuan's Avatar
Default 1970 camaro swap 350 to 454 help ?
Trying to swap a 350 for a 454 big block, need any suggestions on what i am going to need as of new parts or changes to make it fit? These is my first project any suggestions will help. Thanks
Old Feb 1, 2012 | 05:58 PM
Welcome to the forum! Try the search function, there's been many threads on the subject:
Camaro Forums - Chevy Camaro Enthusiast Forum - Search Results
Old Feb 1, 2012 | 06:44 PM
bad436z28's Avatar
welcome to the site,wow a 454 sweet good luck with ur swap should be an easy swap for yah!
Old Feb 2, 2012 | 08:02 PM
prsjuan's Avatar
Yea got a 76 camaro donor with 454 trying to pull out and put in mine
Old Feb 2, 2012 | 08:04 PM
prsjuan's Avatar
Not sure what transmission to use a 400 Turbo or 4 speed super t10 Berg Werner any suggestions?
Old Feb 2, 2012 | 08:13 PM
mikes68's Avatar
4 speed
Old Feb 3, 2012 | 01:56 AM
bOrg wArner
Old Feb 3, 2012 | 10:14 AM
prsjuan's Avatar
is there any adjustments on drive shaft ? any cutting or anything i should know if i go with a 4 speed borg warner st10 ?
Old Feb 3, 2012 | 11:02 AM
bad436z28's Avatar
depends on what drive shaft it originally came from,if its a 400 turbo drive shaft then no cutting required for the 4 speed,if it originally was from a 350 turbo then u will need to shorten the drive shaft.
Old Feb 3, 2012 | 11:38 AM
Yes the 400 is 3/4" longer, and might bind. TH350 and 4 speed are the same length. You might want a new driveline, or at least rebuilt anyway, so small change and not too spendy to shorten.
