power door lock switches do not work on either door
Old Oct 6, 2022 | 08:28 AM
jimkel1's Avatar
Default power door lock switches do not work on either door
Ok seems every time I fix one thing I find another. Started installing new door panels and connected power lock switches and they do nothing neither side. I checked harness into the doors and see no issues. can anyone point me into some steps to troubleshoot this? possible a wiring diagram? How can i test the wires into the harness? power windows work fine. I also checked the 5 pin harness on door and am seeing 12+ volts on 1 pin using the ground from the harness to the door. when I use them I dont hear anything at the actuators so I dont think they are getting anything from either switch. Is there any relays or fuses along way I can check?
Thank you!
Danni Nim
Oct 20, 2016 10:40 AM
Chaotic94
Jan 23, 2011 08:39 PM
gotta99camaro
Jul 11, 2009 12:07 AM
cgilbert23
Jun 9, 2009 07:34 AM
1994chevycamaro
Mar 8, 2009 11:12 PM
