Power Door locks
Old Oct 16, 2016 | 03:04 AM
Danni Nim's Avatar
Default Power Door locks
Hi
Any one has an idea on how to fix passenger door lock?
I have a 2011 Camaro RS. with remote start key fob. Unexpectedly yesterday the passenger's "only passenger" power door lock stopped working at all, it's not responding neither to the remote key nor to the Lock Unlock Button inside the car!
All other options are functioning properly no problem.
I tried resetting the car to factory defaults, but unfortunately it didn't work.
Thank You
Old Oct 19, 2016 | 10:22 AM
Everett#2390's Avatar
You might actuate the driver side door lock button, then try pass door button.
Power for both pass door lock and window goes through driver door switches.
You may have to replace drvr lock switch
Old Oct 20, 2016 | 10:40 AM
You can try grabbing the rubber conduit between the front of the door and pillar, and wiggling it as you try the switch. I've had a couple of cars where the wire broke from getting constantly bent back and forth. I wouldn't expect that on such a newer car, but I wouldn't rule it out either.
wolf_t
Sep 24, 2009 01:14 AM
markcamaro
Aug 23, 2008 04:33 PM
dnulnarts
Mar 6, 2008 03:51 PM
91 Camaro RS
Dec 4, 2006 12:37 AM
chaeridley
Oct 4, 2006 12:02 AM
