power door lock switches do not work on either door
Ok seems every time I fix one thing I find another. Started installing new door panels and connected power lock switches and they do nothing neither side. I checked harness into the doors and see no issues. can anyone point me into some steps to troubleshoot this? possible a wiring diagram? How can i test the wires into the harness? power windows work fine. I also checked the 5 pin harness on door and am seeing 12+ volts on 1 pin using the ground from the harness to the door. when I use them I dont hear anything at the actuators so I dont think they are getting anything from either switch. Is there any relays or fuses along way I can check?
Thank you! |
