Adjust Steering Wheel to Correct Position
Old Sep 9, 2021 | 12:28 PM
walkjim's Avatar
Default Adjust Steering Wheel to Correct Position
Hi all, New to the site. I have a 67 & 69 but just purchased a 70. It's a great car but the steering wheel is off by 120 degrees. I took a look at removing and reattaching to the shaft at the wheel but the horn button will not move with the wheel. I looked down at the rag joint but there is a D or flat on the shaft so it can only go in one way. The intermediate shaft has no splines to adjust. I am unable to figure out how to re-clock the steering wheel and keep the horn button under the wheel. Can anyone tell me the best way to be able to re-install the steering wheel so it is on straight? Where is the adjustment made? Thanks in advance for the help......
Old Sep 13, 2021 | 07:51 AM
walkjim's Avatar
Thumbs up
FYI to all following. I was able to dial in the steering wheel to a perfect position by adjusting the tie rod ends. Also confirmed proper toe in. Car drives straight and steering wheel is straight.
sgreg831
Nov 15, 2012 05:41 AM
Z28beast
82-92 V8 Tech
Feb 4, 2009 02:19 PM
1979RS
70-81 V8 Tech
Feb 20, 2008 07:45 AM
1979RS
Jan 15, 2008 09:37 PM
deswitzki
Dec 28, 2005 11:53 AM
