steering wheel realign
Old Nov 11, 2012 | 07:26 PM
sgreg831's Avatar
Default steering wheel realign
I bought a 69 camaro about 6 months ago and the steering wheel is off a bit. The top or the 12 o'clock position is about at 1 o'clock. What is the best way to realign it? thanks in advance
Old Nov 11, 2012 | 11:50 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
Pull the steering wheel and move it over a groove or two
Old Nov 12, 2012 | 08:16 AM
77thor's Avatar
When I had my front end alignment done the shop also straightened out my steering wheel, which was off by 1/2 a turn.
Old Nov 12, 2012 | 08:42 AM
That's the nice thing about these older cars, the turn signal cancelling pin is on the back of the steering wheel, so moving the wheel a notch or two as needed will keep things "right".
No need to center the front wheels at the steering linkage.
Old Nov 15, 2012 | 05:41 AM
Everett#2390's Avatar
Remove the horn button or crossbar, if Deluxe s/wheel, and look for a notch on the shaft, should be at 12 o'clock, and a corresponding mark on the s/wheel.
The two marks should line up denoting proper alignment of s/wheel to shaft.
On steering box, the flat under the rag joint pinch bolt should be at 12 o'clock.
At center link, it should be at right angles to the Pitman arm and idler arm - both arms should be parallel to subframe.
dashing88
Aug 12, 2013 01:12 PM
BasicConcepts
Dec 3, 2011 03:00 PM
ronald66
Sep 28, 2008 10:00 PM
