yup another problem. starting in park
Old Dec 10, 2009 | 06:42 PM
89.camaro's Avatar
man i had a 76 years ago and had that problem. i finally got it started once and it was in gear wouldnt go back to park. so i had the emergency brake on and let it run. it stalled out for some reason a few minutes later. couldnt get it back to park.couldnt get the key to turn off eighther.and it caught fire under console.smoke was so strong had a hard time getting hood release popped to unhook battery. by then the whole interior was in flames. it was trashed. i pulled motor trans and trashed it. never looked to see what really caused it. was maybe 18yrs old back then.what i am trying to say is be damn carefull and fix it now. dont let it go.i am also in nuetral saftey switch myself. good luck probably just needs adjusted
Old Dec 11, 2009 | 07:38 PM
Originally Posted by Wyo77camaro
That is not true. I've got the shifter on the floor. My P R D 2 1 indicator is on the gauge cluster and my nss is on the colmn. Got it all changed out and all is good, so far. Lol
J.
Well I'll have to eat my words on my second reply. This is TRUE! I took my console apart today to install the B&M Megashifter, and what did I find inside?....A neutral safety swith, complete with reverse switch too! Mounted right there in the middle of my factory linkage. No adjustment on the switch, and it appears the adjustment is done by adjusting the cable end.
PressyP
Jul 31, 2009 03:54 PM
Chriseisenbraun9
Feb 18, 2009 10:45 PM
buddywackos
Jan 31, 2009 09:53 PM
Standalone107
Sep 6, 2008 08:34 PM
White00ss
May 16, 2008 10:49 AM
