Starting problem
Old Aug 30, 2008 | 04:16 PM
Standalone107's Avatar
Default Starting problem
Hey, my friend has an 02 SS 35th anniversary camaro. It does not want to start. You can turn the key to the "start" position and the starter will crank the motor all day long, but it will not fire. We put a new battery in it, and we checked the fuel rails, there is fuel under pressure in the rails. I really am not a chevy guy at all, but when my friends need help i help them out. Any Ideas??
Old Aug 30, 2008 | 08:43 PM
Default RE: Starting problem
Did you check for spark???
Old Aug 31, 2008 | 01:12 PM
We havent yet, but it does have fuel pressure, 50psi with the key on, and 60+ with while cranking. I hope that its not ignition, that is going to be a b***h to locate
Old Sep 1, 2008 | 01:50 PM
The main reason for cranking andno start are:
Ignition problems: check for spark
Fuel problems: check fuel pressure and that the injectors are being fired (use NOID lites), check injector fuses.
Mechanical problems: timing chain & gear problems, blown gasketes, etc..
Screwed up security systems.
May want to use a scanner and see what it shows.
Old Sep 6, 2008 | 01:09 PM
Well, we checked for spark, and nothing. No spark anywhere. We also hooked up a trouble code reader, but to our suprise, nothing came up. Im really lost.
Old Sep 6, 2008 | 08:34 PM
Start by checking the CKP (Crank Position) sensor, PCM will not order spark if it does not see a CKP signal. Then check the CMP (Cam position Sensor). The coils should be good being that all 8 of them won't go bad at the same time. Check ignition relay.
biggin59
Jul 2, 2010 12:22 PM
PressyP
Jul 31, 2009 03:54 PM
Z28beast
82-92 V8 Tech
Oct 14, 2008 09:37 PM
typeomang
Apr 13, 2008 08:59 AM
Fishy Dave
Oct 9, 2006 09:59 PM
