VOLTAGE REGULATOR
Old Jan 16, 2008 | 02:19 PM
camaro70's Avatar
Default VOLTAGE REGULATOR
1970-V8-350 with new alternator.2 wires coming from alternator replaced and connected to old regulator, original disconnected, no other wires connected to regulator. should I reconnect original connection. original wires run true to wire diagram. need help please
Old Jan 16, 2008 | 04:08 PM
got3ofem's Avatar
Default RE: VOLTAGE REGULATOR
Its probably too late, but have you thought of putting in an alternator w/an internal regulator?
If it is possible to return the one you just got, you could get asingle wire alt from jegs or summit at a very reasonable price,and omit the voltage regulator alltogether. Just a thought.
[IMG]local://upfiles/3587/22B4E6D1126740D6970B5733CA3A139E.jpg[/IMG]
Old Jan 16, 2008 | 08:12 PM
JRs72RS's Avatar
February 2009 ROTM
Ditto on that. What you want is a Delco 10-SI alternator. They were used extensively in the 70's, the regulator is internal. You can Ebay a chrome version for about $70. Over the counter at auto parts stores a natural finish for about $45. If you have A/C or accessories requiring more output ask for a CS-130 one-wire. This is a newer GM alt with more output.
palmers68
Apr 8, 2013 08:01 PM
StoveBolts
Feb 3, 2011 09:24 AM
1969_RS
Jul 30, 2010 07:08 PM
87mgte
Dec 14, 2008 06:07 PM
gbic1
67-69 V8 Tech
Nov 17, 2007 08:17 PM
