what engine to buy?
Old Jan 16, 2008 | 08:23 PM
jbd153's Avatar
Default what engine to buy?
where and what should i expect to pay for a 350 engine for a 79 camaro? I never purchased an engine before. Pref remanufactured.
Old Jan 16, 2008 | 08:31 PM
kyphur's Avatar
Default RE: what engine to buy?
are you planning on buying it new? You can get most bare blocks from a junkyard like LKQ for 50 - 100 bucks depending on. If you need to buy the entire engine you can get a gm 350 from jegs or summit for about a grand a half and if it's going in a GM car it's got a 12 month or 12,000 miles warranty. LKQ sells whole engines starting at 250 here by me but you have to pull it from the junker yourself.
You might want to check craigslist also. I see small blocks all the time on there.
Old Jan 16, 2008 | 08:36 PM
jbd153's Avatar
Either a reman or a decent one from a junk yard.I can drop in any chevy 350 small block right?
Old Jan 16, 2008 | 08:41 PM
kyphur's Avatar
Not any 350 small block. Any Gen1 though should fit but you might have to make sure it will mate correctly to your transmission but that shouldn't be too hard. The LS series 350's you'll have to buy special motor mount brackets which you can get from Detroitspeed.com which are based out of Charlotte, NC. Also if it's fuel injected you'll need to get harnesses, etc. If it's carb'd then it should be a fairly standard swap.
Old Jan 16, 2008 | 08:43 PM
jbd153's Avatar
thanks. I never had to replace an engine before so this is kind of a scary experience. The car originally had a 305 in it that was pulled before i got the car. It now has a 350 turbo trans. and all I need is an engine.....i hope...haha you know how that goes...
Old Jan 16, 2008 | 08:48 PM
kyphur's Avatar
Yeah, I know how that goes. My engine and transmission are sitting out in the garage right now. Will be upgrading the cam, valvetrain, and timing here in the next couple of days and hopefully having it back up and running within a few weeks.
Old Jan 16, 2008 | 09:17 PM
got3ofem's Avatar
If you decide to go with a new engine, the ZZ4 series from GM performance parts may be an answer, Extremely good engines, very reliable. morethanjustpower.com has about the lowest price there is from 1,700 up, much less than summit. Ill attach a pic of my ZZ4 350.
[IMG]local://upfiles/3587/95CCEE9D0AA24C48854637E5F86BF10D.jpg[/IMG]
Old Jan 16, 2008 | 09:48 PM
kyphur's Avatar
Ha ha! I can go pick up the engine directly from them. They're like 20 mins away from me. No shippin' for me! ha!
Wait... that means I have to pay tax!
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
