Tunnel Ram Setup
If you're running the dual 450 Holleys, then the 50cc kits are these;
http://www.summitracing.com/parts/HLY-20-11/
I should quote people before I make a statement I guess. I was referring to the OP, he said his car is low mileage. But he's modifying it, I'd like to get the super low mileage grill emblem. I need either that one or a 78 emblem.
Another question.....
I am looking at ignition options. Should I run a vacuum advance distributor or not? Was thinking that the vacuum advance would help the street-ability of it. Does that sound right???
Cly
Cly
Yep, vacuum advance gives it more streetability. I'm running the MSD pro-billet mechanical dist. and don't like it, and am going to be swapping it to a vacuum advance unit. Make sure your engine has enough vacuum to work the advance can, or get an aftermarket can that's compatible.
Read this: http://www.hotrodders.com/forum/dist...1-a-59033.html
I'm running a stock Chevy distributor with a Pertronix kit in it. I really like theis setup, and have the same in my '71 Camaro.
