True dual exhaust
Old Jun 23, 2012 | 10:53 PM
Queue's Avatar
Default True dual exhaust
Just put true dual exhaust on my 79 z28. It is otherwise stock and original. Do I need to adjust the air/fuel mixture to optimize the change in flow? If so, what is the best methodology?
Thanks
Old Jun 23, 2012 | 11:39 PM
I am guessing your engine is using a carburetor. If that is the case, it should work OK without any changes. In a carbed engine all air passes through the carburetor and fuel is automatically delivered according to the air flow. If you made some extreme mods the carb could possibly lean out at high power output and jetting may have to be changed, but the addition of a dual exhaust is not going that far. However; the only way to be sure is to use an A/F meter and run the car on a dyno and see if any changes are needed.
Old Jun 24, 2012 | 03:31 PM
Just get the engine warmed up and take a crusie on the freeway. Then when you get home pull a plug and check the color. If it's not too light colored, then you should be rich enough. If it's too light tan or white you're lean.
Vet76te
Sep 19, 2010 01:09 PM
Vanderkooy325
Jan 4, 2009 11:29 AM
Jokers Z
Apr 14, 2008 07:55 PM
imtico
Feb 29, 2008 09:35 PM
icebergracing
Oct 25, 2005 12:11 AM
