tranny swap
Old Aug 9, 2008 | 12:32 PM
79rallysport's Avatar
Default tranny swap
i have a 79 camaro and im taking out the 305 and the 3speed tranny and putting in a 350 and a 700r4 tranny just wondering if any one has done it i hear that i have to cut the drive shaft and the mounts are goin to be a little different.
Old Aug 9, 2008 | 02:15 PM
kyphur's Avatar
Default RE: tranny swap
Motor should match up same without a problem. Tranny crossmember will be different and you can buy bolt in crossmembers for our years especially with a700R4 but it costs around 220 bucks by itself. You can find that crossmember here.
The reason I know this is because I was thinking about doing the same tranny setup. I already have the 350 but all Gen 1 small blocks should mount the same. Your driveshaft will need to be redone. I don't know total length but there are some places that you can get them custom made from. I think Strange Engineering and Competition Engineering do them if I remember correctly but I'm sure there's others. You can also find a decent machine shop that should be able to do it with little effort. Just make sure they're reputable otherwise you can get an off balance driveshaft which totally blows.
Old Aug 9, 2008 | 07:45 PM
alsome thanks, i found a shop that will do the drive shaft for me.
Isaiah Sias
Dec 24, 2013 08:59 AM
luciora
Aug 14, 2010 09:39 AM
carguylt1
Jul 10, 2010 07:04 PM
mpd228
May 11, 2009 09:52 PM
355CAMARORS
Aug 15, 2006 09:57 AM
