torque converter bolt
Old Feb 16, 2008 | 03:39 PM
thebandit110's Avatar
Default torque converter bolt
is it ok if the bolts for the torque converter touch the converter. cause they are a tad on the long side. thanks - Jon
Old Feb 16, 2008 | 05:36 PM
1969 SS's Avatar
Default RE: torque converter bolt
huh?
I really don't understand the question. of course the bolts are going to touch the converter, how else are you going to bolt it in?
whatever you are talking about, if they are a bit too long, just buy the right size bolts or grind down the ones you have. either way, make sure you are using the correct grade bolts and use Loctite
Old Feb 17, 2008 | 11:08 PM
I think I follow what you're saying. The threaded end of the bolt is going upagainst the body of the converter? Those sure besome long bolts! It won't hurt it as long as they're just "touching"as you describe. If they aredrivinghard against the converter, I would get shorter ones, or grind these down.
Brad777
Oct 29, 2012 11:21 PM
DeathProof
Jul 29, 2011 03:55 PM
chevypowerZ28
70-81 V8 Tech
Jul 11, 2011 12:07 PM
Chevy101
Nov 3, 2010 12:40 AM
Bwalker
70-81 V8 Tech
Oct 21, 2009 05:40 PM
