Torque converter bolt rounded off
Old Oct 28, 2012 | 11:37 PM
Brad777's Avatar
Default Torque converter bolt rounded off
I have two questions.
1- Is it okay to hammer a smaller dia socket onto the head? There isn't too much room to hit it too hard, but needed to get a grip on the rounded head.
2- Is it okay to use some heat on the bolt? I suspect this will heat up the flywheel some...just want to make sure this doesn't cause any damage.
I'm thinking the two of these in conjunction will be effective in getting the bolt out. What do you think?
Thanks
Old Oct 29, 2012 | 10:05 AM
Why not just get a good sized pair of vise grips on it and break it loose? After it's loose then most anything will turn the bolt, even if it's rounded. If the vise grips wont do it, then tacking another nut on the head with a MIG welder will heat it, and suffice to make a good grip surface too.
Old Oct 29, 2012 | 11:52 AM
How close to the next smaller size is it, and have you tried a metric socket? Sometimes metrics can fit in between sizes.
Did you round off the head trying to remove the bolt, or was it "already like that"?
Old Oct 29, 2012 | 11:21 PM
Brad777's Avatar
My son was helping me while I was away and used a 12 pt rather than a 6 pt socket to attempt to remove the bolts. Honest mistake on his part. He's blessed for trying. FYI, I have since managed to get it removed by heating the head up a bit then forcing a 9/16" socket onto the rounded head. I used a 3lb mallet to hit the socket to get it on, however I could only swing it about 6" or so due to the lack of space...probably a good thing. However, I'm always concerned about hurting the flexplate or converter. I guess I'll find out soon.
What a relief!!
Thanks for the posts and good intentions.
wildcat123
Jul 16, 2012 05:06 PM
chevypowerZ28
70-81 V8 Tech
Jul 11, 2011 12:07 PM
thebandit110
Feb 17, 2008 11:08 PM
ranger4620
Jul 26, 2007 01:44 PM
burninrubber11
Jun 27, 2007 02:35 PM
