throttle problem
Old May 17, 2013 | 06:47 PM
78stroker's Avatar
Default throttle problem
So I unhooked the carb to put new metering rods in to adjust the A/F ratio. I hooed it all back up and the throttle cant pull the gas pedal and cable tightly closed. I can do it manually no problem but im a little confused since I hooked everthing back up as it was before.
I tried to adjust the cable all the way to the top and bottom but it didn't change the issue.
Any tips are appreciated.
Old May 17, 2013 | 07:00 PM
oldman9's Avatar
Which carb are you running?
Also please be sure you hooked all the little connecting rods on the side of the carb to the right holes.
Old May 17, 2013 | 07:07 PM
78stroker's Avatar
Edelbrock 750 CFM 1407
Old May 17, 2013 | 08:35 PM
oldman9's Avatar
That is a bit odd. Maby you could post some pics, the other members could help out. Sorry
Old May 18, 2013 | 10:47 AM
78stroker's Avatar
I figured out the Problem, the spring fell under the carb intake that pulls it back and I found it.
Old May 19, 2013 | 11:58 AM
oldman9's Avatar
Awesome!! Glad you found it.
B_Dubya
Sep 23, 2014 11:01 AM
mike6208
Feb 8, 2012 11:51 PM
pimp2303
Aug 22, 2009 07:58 AM
v6camaro00
Feb 15, 2007 02:29 AM
tecmo50
May 8, 2006 11:12 AM
