Throttle Body Or Other Problem
Old Aug 20, 2009 | 10:17 AM
pimp2303's Avatar
Default Throttle Body Or Other Problem
my 305tpi AT has a pproblem of wanting to turn off when i come to a stop. if i throw it in neutral at the light, it will stay running but when i come to a stop it will almost kill or even kill sometime. would this be a throttle body problem or some other problem.
all input is appreciated. thanks
Old Aug 20, 2009 | 10:34 AM
blackz87's Avatar
A big NO....From what you are saying the condition sounds like the IAC valve needs cleaning or replacing with the idle being reset.
Old Aug 20, 2009 | 12:55 PM
ScottD's Avatar
Maybe a vac leak. Check all yer vac hoses, front to back.
Old Aug 20, 2009 | 01:01 PM
I'm seconding the IAC. And generally, a vacuum leak raises the rpm's.
Old Aug 21, 2009 | 09:27 PM
pimp2303's Avatar
were is the IAC located... and what product should i clean it with... maybe carb cleaner or gasoline and how to reset the idle.
Old Aug 22, 2009 | 07:16 AM
blackz87's Avatar
Buy a tech manual or go to www.thirdgen.org, they have a very good tech article on this subject. But my opinion by the above questions you are not a DIY type.
Old Aug 22, 2009 | 07:58 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Kinda OT, but while this most likely true with the car in question, it isn't on quite a few newer cars. I've dealt with cars that ran like total crap, some wouldn't stay running or even start and it turned out to be a vacuum leak.
B_Dubya
Sep 23, 2014 11:01 AM
isaac11
Feb 8, 2009 12:19 PM
94camarokid10
Feb 1, 2009 03:25 PM
im74d
Nov 20, 2008 01:50 PM
Skip94z28
82-92 V8 Tech
Nov 21, 2006 03:47 PM
