steering problem
steering problem
Right now in my 67 camaro I have about 20 degrees of play in the steering while the car is just sitting. It has manual steering and I was wondering what should I look to repair/replace to fix this? My first thought was to replace the grommets in the control arm and sway bar, but I was told I should look at the steering linkage before I replace the grommets. If anyone has a little advice I could use any help, thanks.
RE: steering problem
New sway bar dushings will do very little for your problems. You need to take the car to a good front end shop & find out what the problem is. It could be a bunch of theings, from loose mounting bolts, tie rod ends, steering gear, ball joints, etc.. In any event, do not drive it as you may have a serious accident.
Well, seems like all the things I've been told to look at are possibilities, so I'm gonna have everything checked out. But yeah I'm not gonna drive it for sure, I'm not putting insurance on it till I get it in better condition.
