hurt anything?
Old Oct 24, 2006 | 02:09 PM
hockey511's Avatar
Default hurt anything?
Would it hurt my engine at at all if i ran it without one of the headers on from the lack of backpressure?
Old Oct 24, 2006 | 02:24 PM
shnormo's Avatar
Default RE: hurt anything?
It won't do any catastrophic damage. It might run lean and sound wierd. But as far as I know, no it will not hurt it. Why would u want to do this in the first place?
Old Oct 24, 2006 | 06:39 PM
It will hurt your hears, and probably start a fire under the hood, but I doubt it will hurt the engine.
Old Oct 24, 2006 | 10:27 PM
hockey511's Avatar
I havent the car in a while and i am having trouble getting the driver's side header in.
Old Oct 24, 2006 | 10:47 PM
1983camaro's Avatar
i heard some where that you could possibly burn the valves out by running without 1 or 2 exhaust manifolds/headers.
Old Oct 24, 2006 | 11:38 PM
78 LT modified's Avatar
it will burn the valves if you run it an extended time and toast everything under the hood
Old Oct 28, 2006 | 02:04 PM
10JQKA's Avatar
what happens also is that your valves get hot and when you turn engine off air is right there to get up in there so your valves cool way to fast...that warps or breaks them... plus under hood fire from heat.. wouldnt do it..
kc
Alki70
Mar 12, 2012 09:23 AM
383 79
Jun 27, 2008 12:20 PM
SpecterGT260
Jun 24, 2007 09:12 PM
auSStin
Aug 22, 2006 03:27 AM
