Power Steering Problem
Old Dec 13, 2014 | 08:59 PM
Randy Craig's Avatar
Default Power Steering Problem
I have 1967 Camaro SS. About 1 mile from my house a seal of some sort blew in power steering box and all fluid was lost. I drove car on to house without PS. Since the box was very old I elected to replace instead of rebuild. I replaced it and now it seems pump is not working. I filled it with fluid up to line, started car for a minute, refilled, and nothing.
Any Suggestions?
Old Dec 14, 2014 | 07:09 AM
flat tire's Avatar
my best guess would be , you ruined the pump by running it without fluid
Old Dec 14, 2014 | 08:58 AM
Probably so. I'm going to make sure all air is purged from lines and such. Next step is replace pump.
Old Dec 14, 2014 | 10:04 AM
Icecobra's Avatar
When you run the power steering out of fluid you have to purge the lines. Once started the steering wheel has to be moved back and forth for a few minutes to drive the air out of it. Just sitting there at idle will not force the air out.. It should get easier over a few minutes as the air is purged.. It is possible you burned up the pump itself also and that would mean also replacing the pump.. But try to purge it first and see if that works..
bohuntr
Oct 15, 2009 09:22 PM
The Banks
Jun 26, 2008 01:55 AM
95camaro
May 17, 2007 10:54 AM
cmrz
Feb 23, 2007 11:46 AM
jhop16
Nov 17, 2006 10:59 PM
