Power Steering Problem....
Old May 16, 2007 | 09:38 PM
95camaro's Avatar
Default Power Steering Problem....
Ok i am having this problem with my power steering. The problem is i have none. I put Lucas in incase my rack and pinion was worn out. It helped a very little bit It is to the point where it will work occasionally for maybe one turn. Im used to driving it without power steering but when it does kick in it completely throws me off.
I got into what you can call an accident this past winter. The first slush we had on the ground i went out and i was being dumb i was goin about 85 on the highway. In th center of the highway there is a grass median. Well i was going along trying to make it to the mall in 10 minutes before they closed. Well i hit a little bump and it spun my car in a circle seven times. Well when i hit the grass median it spun me the opposite way 3 times and i ended up about 100 ft down the median facing on comming traffic. When i hit the median i bottomed out really hard obviously and i was wondering if i bent the Rack & pinion. But idk if not what else could it be.
Old May 17, 2007 | 10:48 AM
Default RE: Power Steering Problem....
Check the power stering pump, at times the shaft will shear but remain in place and hide the problem.
Old May 17, 2007 | 10:54 AM
95camaro's Avatar
ok i will do that
Randy Craig
Dec 14, 2014 10:04 AM
bohuntr
Oct 15, 2009 09:22 PM
The Banks
Jun 26, 2008 01:55 AM
cmrz
Feb 23, 2007 11:46 AM
jhop16
Nov 17, 2006 10:59 PM
