Second Gen Brakes issue
Old Mar 8, 2012 | 07:26 PM
RonRico's Avatar
Default Second Gen Brakes issue
Need some advice here. I have a 70 with front disk. The car sat for ???? years before I saved it. I have it running with a fresh 350 and a 350th. But no brake pressure. I have bled the system three times and still no luck. I have a power brake booster w/ master cylinder off a 1977. Since I may have to start from scratch, Will this bolt right in and work if get vacuum to it off the carb.
Old Mar 8, 2012 | 08:01 PM
Prop valve probably is gunked up. So you know and not to sound condesending, they all came w/ discs after 70. Yes i think the booster will work.
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
Vanderkooy325
Mar 25, 2009 11:09 AM
