which octane should i be running???
Old Jun 14, 2009 | 10:46 PM
GRIFF's Avatar
No you would not have the LT1 as a stock engine, I was asking jjz28.
Old Jun 14, 2009 | 10:49 PM
GRIFF's Avatar
The LT1 has the optispark distributor in the front of the engine, center bolt valve covers and the coolant passage in the back of the block.
Old Jun 14, 2009 | 11:33 PM
slvrblt2, your engine has a compression ratio of 8.2:1, which means....low. Your engine would not benefit from running on more than 87 octane. Any comparison of other peoples cars or trucks to your car is totally immaterial.
Old Jun 15, 2009 | 06:14 AM
jjz28's Avatar
yes, mine is an LT1.
Old Jun 15, 2009 | 06:16 AM
jjz28's Avatar
Compression on my 92 ranger 4.0 is 9.0:1.
Old Jun 15, 2009 | 03:18 PM
nscfn8's Avatar
i agree with Camaro 69....everyone's engine's are different, and depending on what you have or did to it, then that determines what you should run...just try and see what works best for you...me for instance can't run under 91 or else ill start knocking, but you probably can get away with 87 for now
Old Jun 15, 2009 | 05:30 PM
GRIFF's Avatar
What is the recommended fuel for the car?
Old Jun 16, 2009 | 01:29 AM
jjz28's Avatar
I'm not sure, I have never checked.
Old Jun 22, 2009 | 12:19 PM
Bamaro's Avatar
Originally Posted by slvrblt2
hey guys i was just wondering, whats a good octane level to run my 79 camaro z28? it has a 350 in it pretty much stocke except for a holley 4 barrel carb and edelbrock aluminum intake, is89 ok or should i be running something higher like 91? thanks
Let your ears be your guide. If you dont hear a knock on 87, use it. If it knocks, move up a grade.
valnzula
Jun 23, 2010 09:25 PM
fetuswrangler
Nov 20, 2008 09:39 PM
evilkal
Oct 6, 2008 02:46 PM
hsdragracer
Jun 28, 2006 03:55 AM
