No spark
Old Aug 17, 2021 | 06:11 AM
Everett#2390's Avatar
What does timing light show when cranking?
Old Aug 17, 2021 | 06:48 PM
I'd pull the cap and turn it over to make sure the rotor is turning,then I'd pull a plug out and plug the wire into it with it laying on the head for ground and see if it sparks when you turn it over with the starter. If it sparks I'd double check that you have the dist. in the TDC #1 Compression stroke.
How old is the HEI? No spark might be a bad coil,could even happen with a new coil.
My93camaro
Jan 25, 2017 09:08 PM
mikes68
Apr 7, 2013 08:22 AM
djsquare1
Oct 27, 2012 03:05 PM
ggraham
Mar 11, 2011 04:08 AM
Luz Hernandez
Feb 26, 2011 09:17 PM
