No spark
Old Aug 11, 2021 | 08:03 PM
Jacob Guin's Avatar
Default No spark
New engine cranks but does not start. Can't seem to figure it out.
Old Aug 11, 2021 | 08:57 PM
Not much information to go on here,what engine what mods what ignition? No spark at all or backfires or what?
Old Aug 12, 2021 | 07:05 AM
Zspoiler's Avatar
check it a step at a time
Old Aug 12, 2021 | 07:39 PM
Jacob Guin's Avatar
Sorry its a sbc 350 5.7 with an hei distributor it doesn't back fire, it just cranks and seems like it doesn't even fire
Old Aug 14, 2021 | 10:45 PM
Did the engine come with the distributor already installed, or did you put it in? If you did, then it might have been put in wrong/out of time, or you could have your ignition wires messed up.
What year is the car? If it was from the points and condenser era, then run a new 12 volt wire to the distributor. The original wire to the coil was a resistance wire (9-10 volts), but that wouldn't be the cause of your no start issue. But do make sure you have power going to the distributor.
Or, is it getting gas? Look down the carb while pumping the throttle. Do you see gas squirting?
Old Aug 15, 2021 | 05:35 AM
Everett#2390's Avatar
Ensure new power supply wire Camaro69 suggested goes to BATT terminal on HEI.
Ensure good ground connection between dist body and block.
Old Aug 15, 2021 | 11:35 AM
Jacob Guin's Avatar
I installed the distributor myself but I was pretty sure I set my initial timing correctly and its a 1976 I do have power to the distributor as well as getting fuel to the carb
Old Aug 15, 2021 | 12:12 PM
Jacob Guin's Avatar
Old Aug 15, 2021 | 07:34 PM
Ahh but did you set the distributor in the correct position when you dropped it in?
#1 cylinder at top dead center compression stroke? Rotor pointing to #1 at TDC compression stroke after turning it over?
Old Aug 15, 2021 | 08:48 PM
Jacob Guin's Avatar
yes the rotor is facing #1 at TDC
