New to CF, questions about speedo
Old Sep 22, 2014 | 08:06 PM
Black74LT's Avatar
Default New to CF, questions about speedo
Hey guys, I have a 74 LT I just picked up recently, going through locating leaks and trying to replace what I can. I have a leak at the transmission pan (TH350), no biggie, but I'm also finding red fluid on what I'm assuming is the speedometer cable. There are two parts. the first is attached to the extension housing, then goes to the subframe, attaches to some other "thing", then another cable goes up through the firewall. All the couplers look pretty good but I keep finding a little leak and a small puddle under that "thing" and I don't know what to call it to either replace or repair. Both pieces are driver side. If I can attach these two pics...
Old Sep 23, 2014 | 09:45 AM
Probably the O ring on the speedo sleeve. The O ring can be easily replaced once you pull it out. Ignore the part labeled "stealth conversions".
91ralllysport
Mar 4, 2010 08:30 PM
95awhite
Aug 2, 2009 08:29 AM
RED94Z
Feb 26, 2009 08:02 PM
Bern1982
Dec 21, 2008 09:05 AM
94Z28interceptor
Dec 12, 2006 02:16 PM
