speedo help
Old Mar 4, 2010 | 08:27 PM
91ralllysport's Avatar
Default speedo help
my speedo doesnt work untill the car is warmed up to 220 degrees whould that be a sensor or the gears inside the trans?
Old Mar 4, 2010 | 08:30 PM
microkid's Avatar
March 2011 ROTM
Technical User
the temp shouldnt be relevant, although that is rather hot. the vss is probably shorted inside or has a broken coil, and the heat makes it expand just enough to work. check the wiring and the connector of the sensor on the rear of the trans. if that looks ok, replace the vehicle speed sensor
doug91rs
May 1, 2011 08:30 PM
x01660
Apr 25, 2011 08:33 PM
moradin
Oct 19, 2010 01:40 PM
nzink
Apr 3, 2007 08:29 PM
94Z28interceptor
Dec 4, 2006 04:54 PM
