LT1/LT4 Tech 1993-1997
speedo
Old Feb 24, 2009 | 03:28 PM
RED94Z's Avatar
Default speedo
I have always wanted to swap my gay 115 speedo to the 150 is there any other mods i have to make?? the harness should be same in dash to hook up but will it read correctly???
Old Feb 25, 2009 | 10:12 PM
black95z28's Avatar
i cant honestly say that i have heard of a 115 speedo on an lt1. what year is your car?
Old Feb 25, 2009 | 10:21 PM
95slvrZ28's Avatar
His car was not ordered from the factory with Z rated tires, thus it was speed governed (the computer actually starts to pull timing) at 108 mph (just under the 112 speed rating of H rated tires) and it came with. I believe if you get the 150mph speedo you'll have to get the computer reprogrammed, but don't quote me on that, I'm not 100% on it.
Old Feb 26, 2009 | 08:23 AM
whammer3024's Avatar
ROTM Winner
it would make sense that you'd have to get it tuned...right? or at least recalibrated which i suppose would probably be done through the computer. i'm not 100% sure either but i agree with slvr that it makes sense you'd have to get the computer programmed
Old Feb 26, 2009 | 06:58 PM
lt4weeda's Avatar
Well its a completly different make, but my buddy switched speedometers in his 95 Dodge 2500 to one out of like a 94 or 95 1500 v8 because the speedo went to like 140 instead of 120 and he didn't have to reprogram anything and the gauge reads dead on. However those trucks came stock with the same tire sizes
Old Feb 26, 2009 | 08:02 PM
95slvrZ28's Avatar
The speedo in our cars are completely electronically controlled by the PCM. You can adjust the PCM for the size of tires, different rear end gears etc. The fact that it isn't mechanical would seem to necessitate a PCM reflash.
doug91rs
May 1, 2011 08:30 PM
x01660
Apr 25, 2011 08:33 PM
moradin
Oct 19, 2010 01:40 PM
nzink
Apr 3, 2007 08:29 PM
94Z28interceptor
Dec 4, 2006 04:54 PM
