Leaking Fuel Pump
Old Dec 6, 2009 | 11:53 AM
AHM84's Avatar
Default Leaking Fuel Pump
Hey Everyone, 71 Camaro fuel pump is leaking out of what I suppose is a overflow hole on the pump. Does anyone have any Idea if perhaps I just may have flooded it or do I need to replace this pump?
Old Dec 6, 2009 | 12:05 PM
The diaphragm inside is shot. Time for a new pump.
Old Dec 6, 2009 | 12:27 PM
AHM84's Avatar
Thanks for the quick response and info. would you suggest I stick to a factory pump or should I upgrade? My 350 is still mainly stock.
Old Dec 6, 2009 | 12:38 PM
I'd stick with a factory style pump, even with a fairly built engine, unless you're running so much carburetion that a mechanical can't keep up.
Be sure to change your engine's oil and fliter too! When the diaphram breaks it can let gas into your crankcase.
Old Dec 6, 2009 | 01:01 PM
A stock one will work fine. And I would get a good name brand, not a cheap house brand.
Sicilian
Aug 1, 2013 11:42 PM
Jeepin
Nov 23, 2011 11:32 AM
th3po1son
Dec 11, 2007 07:09 PM
coolcat
Jun 2, 2006 12:57 AM
coolcat
May 29, 2006 04:25 PM
