Largest tire size for 70'
Old Apr 2, 2010 | 06:32 PM
Osmiumfoot's Avatar
another peek
Old Apr 2, 2010 | 07:37 PM
Originally Posted by Osmiumfoot
Check this baddog out. SB 427 with dinky heads and big cam. I don't know if its going to work but its worth a try before I kick out 3k for good heads. Supposed to run mid 11s without working up a visit to the doctor for hypertension.
Very nice! Are you running a gear drive on there? Looks like a gear drive cover.
Old Apr 3, 2010 | 03:26 AM
Osmiumfoot's Avatar
Its not a gear drive, just a Comp 2 piece cover. Its stout enough to keep the thrust bearing on the nose of the cam from deflecting it, so I really like it.
Old Apr 3, 2010 | 01:43 PM
Looks really cool! I'm just using one of those little aluminum cam button inserts in the front that rests against the stock timing cover. Guess someday it will just wear through the stock cover!
Old Apr 4, 2010 | 01:49 AM
Osmiumfoot's Avatar
I've been running the bearing buttons for years, and you can hardly tell the wear on the back of the timing cover. I don't think they put much pressure against the cover. I keep the end play between 5 and 10.
flowride
Jan 4, 2013 01:13 AM
matteoviviano
Feb 2, 2009 10:42 PM
z28rob18
Jul 4, 2008 11:04 PM
blacufo
Apr 29, 2007 12:24 AM
colombianman33
Jul 30, 2006 10:19 AM
