Largest tire size?
i want to get the most traction out of my 96' z28 and im due for new rear tires, is wider ALWAYS better? or do i compromise more safety than speed?
stock rear end by the way
im not ready to swap in a F 9 inch but thats a future plan
If you really want better traction the key is a stickier compound, the only problem with this is they wear out faster. Wider will get you a little more traction, but not as much as most with wide tires would like to think, more than anything it looks cool. The widest tire you can run without tubbing your wheel wells is going to be a 315/35/ZR17, and that needs to be put on an 11" wheel.
blacufo
Apr 29, 2007 12:24 AM
