Intake problems !!!
#21
With the gaskets in place, can you view the mating surface of the intake to the heads straight on to see that the angles are the same? Even check gaps top to bottom with a feeler gauge or fine wire. If something is different with the angle match, you can end up with a manifold vacuum leak.
carid
Vendor Special Buys
01-20-2015 07:08 AM
