How do I remove the back deck of my '78?
Are you talking about the actual metal part,or just the cover over the rear area.If you mean the cardboard type cover back there,you just need to start at the front edge and get under the vinyl strip and use a putty knife to work the glue loose,eventually you will be able to pull it loose.Also take the side panels and sail panels off to make it easier to get to the edges.
Did you find a good place to get a replacement back deck or are you making one somehow? Any info would be nice since I am planning on painting my '79 RS and would like to replace my back deck which has seen much better days. It is still there holding the speakers but looks like it might go about any time!
Very easy to make one from a piece of masonite, then cover it with naugahyde and it's good to go. I did mine that way, but covered it with wool carpetting to match the rest the rear area.
I never consider time making a car part in the equation. Sometimes I spend so much time making a part that I make about $2 an hr. if I charged myself. It's usually about making it better, or just seeing if I can do it.
