How to remove cable from back of starter switch
Old Jan 12, 2014 | 08:01 AM
jlbonnie2000's Avatar
Default How to remove cable from back of starter switch
I have a 2002 V6 Camaro. The start ignition switch is bad. I am in the process of replacing it.
I have the steering column dropped down and everything is removed. I am now looking at the ignition switch with the cable coming into the back of it.
I have a couple of questions
1) How do I remove this cable?
2) The new start switch has a blue button on it. What is this for?
3) Looking at the old switch, I can see what looks like an adjustment screw. The new switch does not have this screw. Is this how the switch is adjusted?? Do I remove this screw and add it to the new switch?
thanks.........John
Old Jan 13, 2014 | 06:15 PM
Geez!! I see 38 people read this post. Nobody knows the answer?? Or when I might find the answer??
Old Jan 13, 2014 | 06:31 PM
mine had a tab that i bulled to release the switch. yours a 02 is probably different. go here and download the 99 fb file. factory service manual. should have what you need. http://www.mediafire.com/?40mfgeoe4ctti
here is some info for the 93-97
https://camaroforums.com/forum/93-02...mn-info-64804/
Massey's Avatar
Need pics, I know what you are asking about the cable but off the top of my head I cant remember how to disconnect it. I remember it is easy to remove but I cant remember how, I should be able to recall if I can see it from different angles. As for the button... NO clue again need pics.
Massey
jlbonnie2000
Jan 15, 2014 06:54 PM
androzer
Oct 18, 2012 09:57 AM
Stevolwevol
Aug 23, 2011 09:37 AM
larryshon
Jul 28, 2009 02:20 PM
SomeCallMeFonzi
May 19, 2007 04:28 PM
