Hot Fuse Tap
Old May 21, 2020 | 08:23 AM
laconialed's Avatar
Default Hot Fuse Tap
To power new dash instrument panel I need a always hot wire and an accessory power wire. The accessory I'm using is from the existing dash wire harness (pink). As far as I can tell, there is no always hot on that harness. So I'm grabbing from fuse box. I was going to put a fuse tap on the Hazards fuse. Now, is that what is best to use? And, I will be testing with an electrical meter, but does anybody know ahead of time which side of the fuse is power in, power out (need to put tap on out - fused side).
If I get to this today, dash will be back in, heater/AC all re-connected, and - fingers crossed - center console working. I'll put in picture later tonight or tomorrow.
And, as long as I have an experts attention, the dash instrument panel I bought wants sender and ground from fuel tank. Existing wires in harness are pink (power), black (ground) and tan, which I'm assuming is sender. Sound right?
Old May 21, 2020 | 06:39 PM
Everett#2390's Avatar
IDK if 2nd Gen's have it, but there may be a BATTERY spade on fuse panel? Use this spade if present.
Tan wire does go to sending unit and it has a ground back by the tank up in front.
Old May 21, 2020 | 07:13 PM
laconialed's Avatar
sorry, what's a spade?
Old May 22, 2020 | 06:31 PM
The 1/4 inch wide male pin.= pull out a modern fuse, ATC, and see the two males pins, each one is a spade.
Old May 26, 2020 | 08:00 AM
laconialed's Avatar
thanks, found the spades.
chris.langlais
Jan 1, 2012 08:45 AM
G Perkins
Jun 5, 2011 11:59 PM
chazsmith82
Mar 1, 2010 05:08 AM
gotalcoholmanup
Mar 1, 2008 07:00 PM
Scorpio00137
Jul 17, 2006 05:04 PM
