Hot Air Choke not working
Old Jul 12, 2010 | 10:20 PM
kjvforme's Avatar
Default Hot Air Choke not working
My sons 1979 Berlinetta with the 350/gradrajet is having a problem with the choke. The carb appears to be hooked up correctly, but I have a question. The hard steel lines that go into the manifold are loose in their bores. One end is connected to the choke housing and the other is connected to the back of the carb at the top at a vacuum port? If it's connected to a vacuum port wouldn't the steel lines not being hard connected cause a major vacuum leak. Or is the back connection just to allow clean air into the line and the back part of the choke housing is connected to vacuum?
Can I just silver solder these connections back on to make it work once again? I know most don't like Rochester but if adjusted and build right they make an excellent carb.
Old Jul 12, 2010 | 11:37 PM
There is a vacuum nipple on the back of the choke assembly that fits into the carb. And the vacuum pulls manifold heat through the steel tube to heat up the choke mechanism. If that tube connection is loose, or if the choke cup is missing the gasket, you have a vacuum leak. If silver soldering the connection is the only way to make the tube fit tight, then go ahead.
sebi1990
Oct 19, 2010 12:01 PM
kolski
82-92 V8 Tech
Aug 1, 2009 11:05 PM
leestir2001
Mar 21, 2008 05:53 PM
cef2lion
May 18, 2007 01:45 PM
camarorz28
Dec 23, 2006 06:20 PM
