Help!! What do I have??
Old Dec 17, 2018 | 08:03 AM
thatcamaro's Avatar
Default Help!! What do I have??
I bought a Chevy engine a few years ago and was told it was a 383 stroker. I'm finally getting around to working on it. I took the oil pan off so I can run the numbers off the crank to confirm it was a 400 crank. I ran the numbers and they don't match anything I find. How else can I tell if it's really a 400 crank or a regular 350 crank? I can't tell if there is any clearences for the rod bolts so I'm not sure what it is
Old Dec 17, 2018 | 01:35 PM
depending on the crank it may not be clearanced. check the stroke.
Old Dec 17, 2018 | 08:23 PM
Are the heads off yet? A 383 stroker has a .030" overbore (4.030"), and a 3.75" stroke. Measure the travel of a piston from top dead center to bottom dead center. If you come up with 3.75", you have a stroker.
Old Dec 17, 2018 | 08:33 PM
thatcamaro's Avatar
Ok thanks. I'll check that
chevy21
Mar 15, 2009 01:09 PM
Rays70
70-81 V8 Tech
Jan 22, 2008 12:26 AM
Rays70
Sep 19, 2007 10:36 PM
nicknick63m
82-92 V8 Tech
Feb 11, 2007 01:47 AM
69camaro1
Dec 22, 2006 10:09 PM
