Stroker Crankshaft
Old Feb 10, 2007 | 08:57 PM
nicknick63m's Avatar
Default Stroker Crankshaft
I am rebuilding an engine and i have decided to make it into a stroker. My question is should i spend the extra money to get a billet crank or will an offset ground crank be good enough. It will be usedin a street/strip situation.
Old Feb 11, 2007 | 12:24 AM
GRIFF's Avatar
Default RE: Stroker Crankshaft
If your are building a serious engine go with forged, what size stroke are you looking at?
Old Feb 11, 2007 | 01:22 AM
MadMikeZ28's Avatar
If your making a 350 into a 383 all you need is a 400 crank with the main journals ground down to fit the 350.
Old Feb 11, 2007 | 01:47 AM
GRIFF's Avatar
Ifyou havea factory 400 crank and were going cast I would do what Mike said from what I hear they are at least as strong as the import cast cranks. Remember the factory 400 crank is externally balanced you need to use a 400 flexplate and damper. I wonder how much it would cost to offset grind and how much you could gain??
fasttony350
Feb 18, 2012 04:50 PM
thebandit110
May 4, 2011 08:51 AM
AnalyzeFaith
Nov 16, 2010 01:55 PM
benz660r
Aug 9, 2006 12:12 AM
GR95Camaro
Mar 25, 2006 06:17 PM
